error when loading UDF
Old   July 30, 2002, 11:24
Default error when loading UDF
Christian
Hi.
When reading a compiled UDF, I get the following error: "The dynamic link library fl6019s.exe could not be found in the specified path" and then a list of path's. This error message comes when I click the "Open" button in the compiled UDF load box.
The file fl6019s.exe is not on my harddisk.
Does anybody know why. Is it an error in my UDF (don't seem to be) or (more likely) is it because I am missing the file (maybe it is located in the wrong place.
When You search for the file fl6019s.exe on your harddisk. Is it present ???
Cheers Christian
Old   July 31, 2002, 07:34
Default Re: error when loading UDF
Rahul
Hi I too faced this problem when I was trying compiled UDF. I copied one file name fl6000s.exe(similar name) to fl6019s.exe. It worked for me. You can also try this else, you install fluent once again properly. Also don't forget to install vc++ 6 with proper options given in installation manual. Rahul
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
Loading parallel udf Pablo FLUENT 7 March 6, 2011 10:25
loading udf in parallel sytem tahere FLUENT 5 December 13, 2008 01:17
problem loading UDF in parallel fluent Tim FLUENT 12 July 12, 2008 12:59
Problems with loading udf Mukund FLUENT 6 July 6, 2004 02:13
