Injections
Old   August 26, 2002, 05:07
Default Injections
Atholl
Hi all,
I've defined an injection (i.e. particle density, diameter and position in my geometry) using previously converged case & data files of horizontal two-phase flow in an annulus. After some preliminary sessions of playing around with the settings, I've found a couple of problems:
1) My geometry length is around 6m, but no matter what settings I seem to alter, the particle track terminates around half of the length. What's wrong here?
2) When I alter the particle diameter, small diameters (c. 0.0001m) show the particle staying around the low side of the annulus (where it was defined initially). However, if I change the diamter to something larger (i.e. 0.1m) the track shows the particle being lifted up from the low side to the top side. Obviously, the larger the particle, the less likely it is to be lifted or dragged along by the fluid, so why am I getting this contradictory result?
Thanks in advance,
Atholl
Old   August 26, 2002, 14:07
Default Re: Injections
Shiping Liu
For the question 1,I think you might set a too small step number or too short time.
Old   August 27, 2002, 03:54
Atholl
Yes, you are right: I altered some of these settings and it fixed the problem. Thankyou!
Has anyone had any experience with defining injections? I want to find out if a spherical particle of a certain diameter and density will be moved by the prevailing flow field. Is the injection method the correct way to go about this?
I know if the fluid velocity is insufficient, the particle will not move. At higher velocities, the particle may roll, slide or bounce along, and at even higher velocities, the particle will be lifted up into suspension. Can Injections give me this information?
Thanks again in advance
Atholl
Old   August 27, 2002, 10:38
xjrocket
Maybe u would try to calculate Saffman Lift Force.
Defining DPM Particle Injections with a UDF TedBrogan FLUENT 0 April 18, 2011 16:45
Coal Injections problem Carlo FLUENT 0 September 30, 2009 06:15
DPM injection ritmat FLUENT 6 June 26, 2007 02:38
injections Donia FLUENT 4 June 2, 2007 06:40
How to define injections in DPM model lingo FLUENT 5 December 16, 2003 10:22
