August 2, 2002, 13:54 |
GAMBIT help
Hi all, has anybody come across having split edges when you create volume.Intially when i have the surfaces,the edge is single and as soon as i make it volume i get a split edge in one of the surface.how can i avoid it?
August 3, 2002, 07:53 |
Re: GAMBIT help
im new to gambit also...But i was wondering how you make it into a volume with edges? in my case, i used edges,then formed a face(wireframe), then i drew another edge perpendicular to the face.. Use the face and the edge to "sweep face' in the volume command and u will get a volume.. I got a warning message saying faces arent connected but u can use the connect option to connect them..
I think this is the way..plz do keep me informed if u have a better method or if this method is wrong... puck |
August 3, 2002, 17:11 |
Re: GAMBIT help
Well,I wouldn't say it wrong though..the way i make it is make edges where you need to have surfaces and the make a surface out of the edges in any possible way ie,sweep,closed edge surface,skin surface or any other method available.and then join all the surfaces to create a perfect volume.thats all i can think of. Mavinakere
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Does Gambit has a maximum allowable grid number? | spartan1516 | ANSYS Meshing & Geometry | 7 | March 25, 2010 09:08 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Problem starting Gambit | ViHAR MALViYA | FLUENT | 0 | November 10, 2006 10:26 |
