-   -   compiled udf? (http://www.cfd-online.com/Forums/fluent/30125-compiled-udf.html)
bonny August 4, 2002 23:50
compiled udf?
hi,all
now i am trying to use the compiled udf in fluent5.5, the error comes when i execute the NMAKE, that is:
NMAKE: fatal error U1073: don't know how to make '..\..\src\d:\fluent-cvd\libudf\src\inlet.c' stop.
d:\fluent-cvd is my work directory and inlet.c is the source file which i defined.
Could anyone tell me why ? Thank you in advance!
bonny
AnnaG August 6, 2002 17:03
Re: compiled udf?
Try compiling in the libudf directory using the makefiles provided by Fluent. This info is available in the UDF manual.
bonny August 8, 2002 21:49
Re: compiled udf?
thank you! but I just did it according to the udf manual,it does not work. i don't know why. bonny
David August 10, 2002 10:49
Re: compiled udf?
Nmake doesn't work means that this VC command is not accessible on your current operation environment.You should set the VC path manually if your OS is Win98. But if your OS is Win2000 or NT, this environment variable will be added automatically when you install VC.
bonny August 10, 2002 23:01
Re: compiled udf?
Thank you very much! you are right. now it can work right.
bonny
