how to increase face mesh no.?
Old   August 6, 2002, 14:32
Default how to increase face mesh no.?
Shankar
On a particular face which am face-meshing, am not able to increase the mesh no. whatever scheme or intervals I try, what could be the reason?This is the first face being meshed.Thanks.
Old   August 6, 2002, 20:29
Default Re: how to increase face mesh no.?
david
I faced similar situation.
Did you mesh the edge before meshing the face? Could you try mesh size scheme of the face? .1, .2 or whatever you want.
It should work fine.
DC
Old   August 7, 2002, 04:04
Keil
When you are using tri mesh in 2d model, the maximum face number is 100,000.
This is the default value of GAMBIT.
If you want to make a mesh more than 100,000, you have to change the default value.
Regards,
Keil
Old   August 7, 2002, 04:38
Laika
try to select the option 'remove lower mesh'
Laika, still orbiting
Old   August 9, 2002, 15:48
Shankar
Hello all Thanks for your responses.It helped. Shankar.
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
[GAMBIT] Face Mesh distortion Forrest ANSYS Meshing & Geometry 0 June 9, 2009 11:50
problem related to mesh naveen CFX 3 March 25, 2006 08:47
