August 28, 2002, 02:38 |
regarding solid continuum...
DEar all,
Im modelling conjugate heat transfer in a contracting duct, with small annular disc-like volumes fixed inside the contracting duct(modelling a hair-dryer actaully). The disc-like volumes are the heat sources and im required to put in volumetric heat generation in the discs. I created this model in GAMBIT...and defined the discs as solids and the rest of the volume as fluid(air). After iterating, i realise that my temeprature are heating really high..around 2800K!..which is impossible as the material im using is aluminium..Im told it should only go up to around a few 100K. Wht should i do to decrease the amount of temperature? Do i have to define the solids as wall instead? Cos i read from Gambit tutorials tht defining them as solid, only enables conduction inside the solid...no convection. Plz help... Puck |
August 28, 2002, 19:09 |
Re: regarding solid continuum...
Hi, Puck:
I think the problem you met in your case is due to the non-conformal mesh you may have generated. Please read the Fluent online help about conformal/non-conformal mesh. Wei |
Display Modes | |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 4, 2013 00:04 |
Defining Solid Zones Not working | elmcmaster | FLUENT | 3 | May 22, 2009 08:14 |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 16:20 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
setting boundary and continuum in GAMBIT | Hakeem | FLUENT | 0 | August 14, 2000 16:32 |
