Home > Forums > FLUENT
Plz help in using "Patching"..
Old   August 29, 2002, 04:59
Default Plz help in using "Patching"..
Deadly
DEar all,
I currently iterated a model using a velocity of 5m/s and saved the iterated case and data.. I need to try another case, now with 10 m/s but using the case and data from the previously iterated 5m/s model.(for faster convergence) To do tht, i read the case and data file of the 5m/s model and went to patch to increase the velocity to 10 m/s. Though, the iteration started from the previously converged data, the residuals plot showed a vertical line drawn after the residuals plot for the 5m/s converged data...and the residuals for the 10m/s model started from the vertical line onwards.. It looked like as though the solver wasnt using the results of the previously converged data..and was iterating all over again for the 10m/s model.. CAn someone help me confirm whether wht is going on is normal?
Puck
Old   August 29, 2002, 22:16
Default Re: Plz help in using "Patching"..
david
Sorry I am confused. Please clarify:
Did you patch the velocity to 10m/s and left the inlet velocity to 5m/s ?
The residuals may jump up, but should calm (come) down shortly !!
DC
Old   August 29, 2002, 22:47
Deadly
Initially when i was running the 5m/s model, i initialised from the velocity-inlet(which i had created in Gambit) Then i was asked to run a 10m/s using results calacuated from the 5m/s model.. Therefore, i read the case and data file from the alredy iterated 5m/s model and patched the velocity(z velocity) to 10m/s.. However, when i stopped the iterations todae to check if the velocity inlet was indeed 10m/s(by doing a surface integral on the inlet), i found tht it is still 5m/s!.. How do i solve this problem? Plz do help..cos me running out of time ready.. Your help is greatly appreciated..
Puck
Old   August 30, 2002, 01:20
Deadly
Just to be precise..Once i patched the velocity to 10m/s, i just clicked iterate form the last set of converged solution(whish is the 5m/s)... so the current case started iterating from where last case stopped..
DO i have to initialise after patching?..if i do tht, i get the ,message"Discard previous data"?.. I need the previous data...how?
Puck
Old   August 30, 2002, 08:36
pp
Just change 5 to 10m/s in your VI panel and iterate. You do not need to patch domain.
Regards,
pp
Old   August 30, 2002, 08:47
Deadly
Whts does VI panel mean? If i do this, will it start iterating from the 5m/s iterated results?
Sorry..im still quite new to fluent.. thnx..
Puck
Old   August 30, 2002, 16:15
pp
Velocity Inlet panel (or whateveer you have Mass flow Inlet etc.).
Yes it will start from 5m/s calcilated fields.
1.Set 5m/s
2.Iterate - convergence
3.Set 10m/s
4.Just Iterate
BR, pp
Old   August 30, 2002, 22:55
Deadly
sorry to bother again.. From your reply, i gather i dun need to click initialise again when i change the boundary conditions to 10m/s right?
Meaning, i dun even need to use patch at all?
Old   August 31, 2002, 05:41
pp
No you do not need to initialize any more.
Old   September 1, 2002, 23:48
Deadly
okie..thnx for ya help...
Thread Tools
Trackbacks are On
plz help its urgent garima chaudhary FLUENT 0 September 25, 2007 05:28
plz ......help me out.....************************ krishna FLUENT 2 January 10, 2007 03:53
"stackdumpfile" Plz help me urgently.. slaton ibrahimovich CD-adapco 1 September 12, 2006 15:01
Doubt - while running iteration, plz help sak FLUENT 0 September 6, 2005 23:16
How to export from Acad into gambit plz! pah FLUENT 2 April 28, 2005 01:50
