Fluid flow
Old   August 29, 2002, 08:25
Default Fluid flow
ser chong
I am currently doing my final year project on the "Analysis of Pressure Transients Caused by The Entry of A Train Into A Tunnel".
Is there any websites, books, journals or tutorial that i can refer to that is relevant on how to model a train entering a tunnel portal in 3D space??
Please advice...
Old   August 29, 2002, 22:25
Default Re: Fluid flow
david
Do you have access to massive parallel computing facilities ?
DC
Old   August 30, 2002, 01:24
ser chong
sorry, i do not really know what is "massive parallel computing facilities" but i think i will be able to access most of the computers in the school. By the way i am using Gambit 1.1 and Fluent 5/6 for my work.
Old   August 30, 2002, 21:59
david
How details you wannna model of the structure of the train ? Are the humen travelling in the train ? Will they be breating ? What about heat loss from their bodies? Are they of same size ? What kind of engine are you considering to consider the heat generation? The tunnel itself is of regular shape ? ser chong you are in trouble !!! DC
Old   August 31, 2002, 19:54
ser chong
Basically, i would like to investigate the pressure pulses generated and propagating in the tunnel during the entering at the tunnel portal.
Modeling a simple model will do, i am also assuming no wheels, condensing units and others under or on top of the train. It would just look like a long rectangular block entering a rectangular hole.
Later, i would also like to know what type of portal entry shape will reduce the pressure waves.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
MR Fluid Flow through microchannels Sinan FLUENT 0 September 18, 2004 00:03
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
