-   -   Grid Check error (http://www.cfd-online.com/Forums/fluent/30240-grid-check-error.html)
Taher August 29, 2002 13:39
Grid Check error
Hi all, I am currently working on a project to analyse flow in a purging tank .The Grid is read in Fluent but the Grid Check gives me a warning : Grid Check failed Is this a Gambit error in meshing or is it correctable in Fluent. Thank you for your time. Taher.
david August 29, 2002 22:20
Re: Grid Check error
Does fluent say "Thank you for your time" ?? :)
Well, definitely this is an error while doing the meshing in Gambit. You have to correct it in Gambit.
DC
Taher August 29, 2002 23:32
Well actually , i meant to thank you for your time... Well anyways ...I corrected the meshing I had some real skewed ones but now I have a new error ... after the problem set up , when I say solve iterate Fluent says that : Divergence detected in AMG solver: x momentum. any clue on this one? Thanks once again.
Eadidi August 30, 2002 09:55
You may select'all-zones'when you Solve-init...
