-   FLUENT (
-   -   special injections----Help! (
fanadam September 4, 2002 11:37
Hello, everyone! I'm going to simulate a kind of special injections, which have different positions at different time. Who can tell me how to do it? Thanks a lot!!!
Sridhar September 5, 2002 07:07
Re: special injections----Help!
Hi Fanadam,
You can inject particles in different positions at different times using, Define->Injections->Create-> and in point properties you can specify the position of the point, start time and end time of the particle. If you are injecting multiple particles go to Injection type->Group.
I Hope this helps!
david September 6, 2002 04:20
A) Save the journal when you inject one set of particles B) Copy that journal whatever times you want and modify the injection type, time...
fanadam September 6, 2002 11:11
Thanks, anyway! But I can't define the initial time or end time at Define-injection-creat. There are no the options in the panel at all. Do you know the reason?
Sridhar September 6, 2002 11:24
If you like, you can send the case file to me. I will see if I can do anything.
