ultrahigh pressure water jet
I wanna simulate the ultra high pressure water jet under submerge condition. who know somrthing about this such as the physical parameters and the B.C? Furthermore, if including volume compressability into control equations, how to deal with it? thanx£¡
Hi kaiser,
Are you still doing the jet simulation? I'm trying to simulate ultrahigh pressure water jet recently. Mixture multiphase modle and Schnerr-Sauer model are used for the cavitation, and the turbulence model is set as k-epsilon. The simulation result is different from the experimental result, I wander if the compressability should be considered. Do you are any findings about that? |
