Home > Forums > FLUENT
UDF for DEFINE_EXCHANGE_PROPERTY
Old   October 2, 2002, 05:28
Default UDF for DEFINE_EXCHANGE_PROPERTY
Pravesh Kumar
hi In writing UDF For DEFINE_EXCHANGE_PROPERTY I am having three phases.I can't increase the no. of arguments for third phase as it is fixed. Then how can i take into account the third phase.
Help needed.
Old   October 3, 2002, 04:57
Default Re: UDF for DEFINE_EXCHANGE_PROPERTY
lohen
Hi, you have to declare one thread for one phase :
thread_g=THREAD_SUB_THREAD(mix_thread,f_col); thread_l=THREAD_SUB_THREAD(mix_thread,s_col);
mix_thread is the mixture thread, from what you reach the other phase. f_col and s_col represent the phase which are in the first column and in 2nd column of the table Phase/Interaction in fluent. So you can declare as much as phase as you want.
Have a look in UDF Booklet in Fluent Documentation.
Old   October 3, 2002, 11:26
Pravesh Kumar
Hi Thanks For your suggestion. I have already gone through the UDF Booklet in Fluent Documentation.
/* find the threads for the gas (primary) and solids (secondary phases) */
thread_g = THREAD_SUB_THREAD(mix_thread, s_col);/* gas phase */ thread_s = THREAD_SUB_THREAD(mix_thread, f_col);/* solid phase*/
For the one more phase(liquid) which will be secondary as there will be only one primary phase should i write? thread_l = THREAD_SUB_THREAD(mix_thread, f_col);
Then f_col will be comon for both solid and liquid phase.Is this right approach?
Waiting for your suggestion. Thanks
Old   October 4, 2002, 09:03
lohen
Hi, look in fluent the table, in the menu Define/Phases/Interaction to see which phase is in the fist column and in the 2nd one. if your secondary liquid is in the first column then thread_l = THREAD_SUB_THREAD(mix_thread, f_col); is correct. Anyway, I think fluent considers interaction between secondary phases and primary phases first and after interactions between secondary phases.
Ciao
Old   October 7, 2002, 01:20
Pravesh Kumar
hi Thanks!! Hopefully it will work out. How to print the values of exchange terms from UDF to cross-check it with hand calculation to verify that they are giving correct values.
Waiting for your suggestions.
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Dynamic Mesh UDF Qureshi FLUENT 1 December 2, 2009 01:27
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
