October 10, 2002, 16:19 |
question of DPM model
Hi, everyone I have two questions on the DPM model. 1. If my volume friction is larger than 10%, let say about 40%, can I still use DPM model to get rough results. If not, which kind of model I should use. ( I need to know the partical distribution)
2. How can I know the grid resolution is collect for the DPM model. I have a simple case, with different size of grids. One has 20,000 grids, for this case, I got 2500 particles. The other has 50,000 grids, I got more than 5000 particles. Many thanks |
October 10, 2002, 16:52 |
Re: question of DPM model
If your volume fraction is greater than 10% you must use the granular model as DPM won't account for particle-particle interactions that are important.
For the other question, the grid resolution is immaterial. regards. CFD Newbie |
October 10, 2002, 17:30 |
Thanks for your reply.
Could you tell me that why the grid resolution is not important? how can I tell my result is correct if I got different results by using differnt number of grids? And why I got differnt particle number? Sorry for so many question. Many Thanks Cindy |
October 10, 2002, 22:21 |
For the sake of the particles, resolution is not important but you must do the grid analysis until you obtain independence for the resolution of the flow equations.
Fluent releases a particle for every cell you have in the surface, so the more cells you have the more particles. If you analyse impact of particles, look at the percentages instead of the absolute number. The only way to know if your simulations are OK is by comparing them with quality experimental results. Cheers Newbie |
October 11, 2002, 13:54 |
Thanks so much for your help.
Have a nice weekend Cindy |
October 17, 2002, 03:46 |
some comments:
--with volume fraction of 40 % you should indeed not use DPM. Granular can be an option, but maybe the particles are not granular. What kind of particles do you have, Cindy? Droplets, powder, ...? --CFD Newbie tells Fluent releases one particle per cell. That's indeed the case with a surface-injection (and more correctly: it's one particle per face), but there are numerous other possibilities. You can also create an injection-file and release as much particles as you want. --The grid resolution needed for good results have indeed nothing to do with the dpm-model. If you don't have experience with modelling for your application, you should test several grids and compare the results. good luck, Laika, still orbiting |
October 24, 2002, 23:51 |
where is Granular model?
October 25, 2002, 03:51 |
it's one of the options for Eulerian multiphase simulation.
November 18, 2002, 21:58 |
Hi Newbie, you said that fluent releases particles at every cell? Does not fluent release particles on the surface that you define (for instance, inlet surface?)
Question on introducing new terms into an existing model | 351Cleveland | OpenFOAM Programming & Development | 0 | January 26, 2011 06:48 |
C_UDMI Question in DPM | Prashanth | FLUENT | 5 | August 20, 2009 04:35 |
URGENT QUESTION ABOUT DPM EROSION!!!!!! | alex | FLUENT | 2 | October 28, 2005 06:33 |
DPM model in FLUENT | Jürgen Schmidt | FLUENT | 0 | October 27, 2005 14:39 |
DPM vs Species transport model | osh | FLUENT | 0 | August 19, 2005 22:15 |
