Using two UDFs in a single geometry
Old   November 6, 2002, 13:36
Default Using two UDFs in a single geometry
Salman
Hi *, I want to use two UDFs in a single geometry. Does anybody know if it is possible?
I have a simple channel, and I want to define one UDF on the top wall and another UDF on the bottom wall.
Please reply if you have any idea about it.
Thanks.
Old   November 6, 2002, 15:16
Default Re: Using two UDFs in a single geometry
Glenn
I was trying to do a similar thing. I found that I could only put 1 udf on any one boundary condition (however it may be possible to different types of udf (e.g. velocity and a property) on a single b.c.) Therefore you can just define 2 different boundary conditions for each part..and 2 different udfs and then just set them up in the boundary conditions. Glenn
Old   November 7, 2002, 03:13
Rahul
Use two function in same file. Give different name to each function. It will definatly work. If you any doubt reply me with your problem in detail Regards, Rahul
Old   November 21, 2002, 13:08
Default Thank you
Salman
You have solved a big problem that I was facing. Thank you Glenn and Rahul. I really appreciate your replies.
[ICEM] Create geometry (iges or step file) from fluent mesh muketa ANSYS Meshing & Geometry 10 August 5, 2015 05:38
importing geometry into starccm krishna086 STAR-CCM+ 0 November 28, 2010 21:54
car geometry Arjun FLUENT 4 September 1, 2007 15:08
urgent help! car geometry Arjun FLUENT 0 August 13, 2007 13:07
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
