October 9, 2002, 09:14 |
Fluid / Particle Interaction
Hi! I have a (hopefully trivial, at leat for someone out there) problem: I am trying to simulate the acceleration of abrasive particles (garnet) in a high velocity fluid stream. I have a pressure in- and outlet and a surface particle injection (fluid/particle interaction switched on). The problem is: After iteration, the particles have in every position exactly the same speed as the fluid, so that they appear not to have any inertia. What am I doing wrong? Thanks in advance, Alex
October 10, 2002, 05:40 |
Re: Fluid / Particle Interaction
hi i think u should try the fluid inlet and a solid inlet(high density fluid in eulerian- eulerian grannular model ) instead of the surface particle injection. that may help u . beacuse in surface particle injection solid behave as inerts. so they acuire same velocity as that of fliud.
October 10, 2002, 10:49 |
Have you turn on gravity ( a must)?
What is the density of your particles?, if small, inertial effects are not present. Is your particle tracking in unsteady state? Have you tried particle-flow interaction? All these factors have an impact on the behavior of your particle tracks. Try all of them. Cheers CFD Newbie |
October 11, 2002, 05:53 |
I am looking into moddeling a similar flow. I want to model diesel exhaust flow with very many different constiuants. is this possible in fluent. Any ideas. Thanks
October 21, 2002, 12:21 |
Alex:
Your particles will have have more or less the same velocity as the fluid if the particle size and/or density is very small (in this case fluid inertia dominates the particle inertia)and if the number of particles is not large enough to consider a 2-way/4-way coupling of the multiple phases. Also, as you would have observed, (for a 1-way coupling) the particles will follow the fluid streamlines all along unless there is any solid obstruction in their path. Hope this helps. |
Fluid Structure Interaction | fw407 | OpenFOAM Running, Solving & CFD | 9 | February 14, 2013 17:25 |
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) | Julian K. | CFX | 2 | September 15, 2011 15:30 |
ANSYS problem in solving fluid fluid interaction | Fayyaz | CFX | 0 | July 24, 2006 09:03 |
interaction time between particle and eddies | Steve | FLUENT | 0 | April 10, 2001 18:17 |
Big particle interation with fluid in DPM | olivia | FLUENT | 1 | January 15, 2001 04:32 |
