Iteration Variable!
Old   October 25, 2002, 15:12
Default Iteration Variable!
Ugur
Hi;
Does anybody know the variable where the current iteration number is stored? I'm trying to code a udf which has to be accessed every 5-10 iterations.
Thanks...
Ugur
Old   October 27, 2002, 10:02
Default Re: Iteration Variable!
Carsten Dehning
I know that there is no global fluent variable containing the current iteration value. Here is my quick&dirty workaround coded in the UDF's.
static int my_iter_counter = 0; static int exec_my_udf = 0;
DEFINE_INIT(...) {
my_iter_counter =
exec_my_udf = 0;
... init something else here ... }
/* called after each iteration */ DEFINE_ADJUST(...) {
* switch UDF exec on at each 10th iteration,
* else off, start with on (iteration 0)
exec_my_udf = (my_iter_counter++ % 10) == 0;
... adjust something else here ... }
/* called for each cell/thread.. it depends */ DEFINE_SOURCE/PROPERTY/ETC(...) {
if (!exec_my_udf)
return; /* or return 0 or whatever */
... execute UDF ... }
This works fine.
With best regards
Carsten Dehning
Old   October 27, 2002, 16:52
Ugur
Thanks for your reply, By the way I have found that the iteration variable is stored in a vector called count2[nres-1]. To use this you can define a variable, such as int itervar=(nres==0)?(1)(int)count2[nres-1]); Thanks
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
