Error: get_udf_function
Hi, I've just written up some code compiled UDF, . It compiled OK (which doesn't mean much) but I get an error when fluent tries to call the function:
Error: get_udf_function: function Cell_mass_diffisivity has wrong type: 0 != 2 Error Object: () What does this mean and how can I fix it? I am a novice at C programming so it is probably something majorly wrong with the variable and function types I'm using. Here's the code: #include"udf.h" DEFINE_PROPERTY(Cell_mass_diffisivity,cell,thread) { real Ks; double temp=C_T(cell,thread); double YI=C_YI(cell,thread,0); Ks=(0.58+0.03*(temp-273.15)+0.0002*(temp-273.15)*(temp-273.15)+(0.001*YI*YI))*pow(10,-9);*/ return Ks ; } |
Re: Error: get_udf_function
your word 'diffissivity' should be 'diffusivity'
why do not you use interpreted udf? |
hi yawi i use diffisivity et nor diffissivity????? i use compiling mode because ia use static in other udfs. thank you
hi
"include" and "DEFINE" can not be on the same line! you should write as follows: #include "udf.h" DEFINE_PROPERTY(Cell_mass_diffisivity,cell,thread) |
