when to define the boundary of interior
Old   October 25, 2002, 04:02
Default when to define the boundary of interior
tony
hi,i am simulating air flow in house.Now the problem is that how to define the boundary of the door or the window between the rooms?And why?
Old   October 25, 2002, 04:11
Default Re: when to define the boundary of interior
Laika
I don't understand your problem. Just tell Fluent it is a wall. No?
Laika, still orbiting
Old   October 25, 2002, 08:57
wind
which version of fluent do you use?
Old   October 25, 2002, 09:45
Glenn
It depends exactly what you want to do. You can set up an "artifical" boundary. If using Gambit, set the plane as an interior. When you see this in Fluent, this plane is in the boundary conditions but it does not affect the results, i.e. You can read values from this plane but the slution acts as if this plane was not there. However if you want this "wall" to have conductive properties etc...I think you set as wall. I dont know how to set up the conductive properties etc.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
defining flux across face for interior boundary Sandilya Garimella FLUENT 2 October 10, 2009 00:05
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
Boundary condition : Interior rakib FLUENT 3 June 23, 2000 14:31
