-   -   Iteration Variable! (http://www.cfd-online.com/Forums/fluent/30434-iteration-variable.html)
Ugur October 25, 2002 15:12
Iteration Variable!
Hi;
Does anybody know the variable where the current iteration number is stored? I'm trying to code a udf which has to be accessed every 5-10 iterations.
Thanks...
Ugur
Carsten Dehning October 27, 2002 11:02
Re: Iteration Variable!
I know that there is no global fluent variable containing the current iteration value. Here is my quick&dirty workaround coded in the UDF's.
static int my_iter_counter = 0; static int exec_my_udf = 0;
DEFINE_INIT(...) {
my_iter_counter =
exec_my_udf = 0;
... init something else here ... }
/* called after each iteration */ DEFINE_ADJUST(...) {
* switch UDF exec on at each 10th iteration,
* else off, start with on (iteration 0)
exec_my_udf = (my_iter_counter++ % 10) == 0;
... adjust something else here ... }
/* called for each cell/thread.. it depends */ DEFINE_SOURCE/PROPERTY/ETC(...) {
if (!exec_my_udf)
return; /* or return 0 or whatever */
... execute UDF ... }
This works fine.
With best regards
Carsten Dehning
Ugur October 27, 2002 17:52
Thanks for your reply, By the way I have found that the iteration variable is stored in a vector called count2[nres-1]. To use this you can define a variable, such as int itervar=(nres==0)?(1):((int)count2[nres-1]); Thanks
