turbulent recirculating flow
Old   October 29, 2002, 12:25
Default turbulent recirculating flow
Abhijeet Vaidya
hi friends,
You must be aware of ustar & yplus as fluent defines it ! Going by their definitions , I was thinking that they should be exactly same if ystar is > 11.25. But when I solved turbulent flow over an expanding channel (pl note that this is a benchmark problem for laminar flow so the geometry of this channel must be familier to the readers), then yplus goes to zero at the reattachment poing which is obvious but even in the regions where ystar is > 11.25 , there is difference in the value of ystar and yplus which means that even when ystar > 11.25, still u_tau = (cmu^0.25)*(tke^0.5) does not hold ? But theory says otherwise ! Can somebody help ?
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 01:00
Difference between recirculation zone and turbulent flow region ashtonJ Main CFD Forum 0 September 16, 2011 03:46
Patch a bubble inside turbulent flow Helmi FLUENT 0 February 4, 2011 04:54
Turbulent flow through hexagonal circular pipe yogesh@cfd Main CFD Forum 0 November 9, 2010 23:10
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
