-   -   modelling of flow between methane and air (http://www.cfd-online.com/Forums/fluent/30459-modelling-flow-between-methane-air.html)
satya November 2, 2002 13:59
hi!!
is it possible in FLUENT 5.4 to analyse the flow between two fluids (methane and air) without any chemical reaction. i tried to use injections but in that methane is not mentioned...plz help me
bye satya
banana nana November 5, 2002 05:23
Re: modelling of flow between methane and air
i am also trying to do methane - air combustion, however since ihave to analyse natural gas combustion, i am using partially premixed combustion model (since NOx models are not available with premixed-combustion models). well you can try partially premixed model also, for methane and air.
Laika November 5, 2002 10:15
use species transport, and define your mixture components in the material-panel.
Laika, still orbiting
cfd guy November 5, 2002 10:19
Hi, I'm a newbie in Fluent but I believe that you can use the Eddy Break Up Model. Is it available on the code, right? Well, once you've set up your problem find out a way to set the A constant of the reaction rate (which is function of turbulent parameters) to zero. Then you'll have a null reaction rate giving you no products. This may work.
Good luck, cfd guy
banana nana December 3, 2002 11:53
and if you are still not able to do it
drop me an email, i will send you relevent files and instructions in detail to model it.
thanks
khalaf April 3, 2009 06:32
wanted
Originally Posted by banana nana
;103610
thanks
Plz can you send your relevant files and instruction in detail to model it to this email "talkh2005@yahoo.com"
