Convergence problem...again
Old   November 19, 2002, 02:02
Default Convergence problem...again
moiami
I know the question has been asked to death b4 but I have difficulties in tracking the answers that can specifically answer my questions:
1. How to know when my solutions have converged? What I did was to run it using the default convergence criterion in the residual pop-up menu and as long as the curves haven't become horizontal I add the zero's in the criterion. Is that the correct way?
2. When to stop the iteration? I read somewhere that as long as the 5 numbers in the console (print off of the residual values) e.g. 5.2661e-06 are not the same for 50 iterations than I have to continue iterating. The problem is my residual curves have long gone into a horizontal mode but the 5 digits are still experiencing +/-0.2000e-06, small in my eyes...but I don't dare stop the iterations. Was what I read true? What's the range of fluctuation that is safe for me to stop my iteration then?
Thanks
Old   November 19, 2002, 03:20
Default Re: Convergence problem...again
Boris
You should monitor the parameters of your interest,say the drag or average temperature of a certain surface, etc, to decide whether the solution is really converged or not. It is more realible than monitoring the residuals.
Old   November 19, 2002, 23:15
Alamgir
Moiami,
1 if u look at the residuals and all the residuals values decreased by 3 order then it would be considered as converged results. And when any values remain constant ie horizontal after getting few at least 2 order decreased then it would be considered as converged. if not then never user 0 in the covergence criterion but decrease the under reluxation faction in solve>control>solution menu. and see the effect.
2 if within 50-60 the values of all residuals get 3 order decreased then it is not considered as converged then put another 0 in the converge critera to allow run more iterations.
go ur own. goodluck
Alamgir
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
