[Sponsors] | |||||
Hello! I´m working on a project that concerns two-phase flow of air and water in a pipe. I´m using the VOF-model in Fluent 6 and I have encountered a few problems. This is the first: When I, after convergence of the simulation, go to check the fluxes I find that the massflow out of the pipe differs alot from the massflow at the inlet! I then run a new simulation and use a monitor at the outflow surface to monitor and plot the massflow. This showed that the massflow out of pipe varied between 1/10 to 5 times the massflow at the inlet!
Does anybody know why this is happening? Thank you! /Victor |
Your problem is still unsteady (if converges properly)
DC |
Ok, but how about the law of massconservation?
Hi, If you do 5 sec unsteady simulations, you should check:
[Total mass in-total mass out= total accummulation] in this 5 secs Are you checking mass flux at certain time? DC |
Hello David!
First of all I would like to thank you for your answers. The answer to your question is that I check the mass flux at every time step. To me it looks like the massflow in average over a number timesteps is somewhat equal to the constant inflow. So maybe if I collect the values of the outflow and calculate an average, I could get some proper results? But this will still not cut it for me because in my problem I have two outflows and I`m interested in how much of the incoming water that goes out of the outflows respectively. The only way I know to do this is to check Report/Fluxes/Massflux, choose water and then pick the inlet and the two outlets. But this will only give the result at the last timestep simulated and not some average for the whole simulation. So I´m still a bit confused... Another thing... What do you mean by total accummulation? and how do I check it? Victor |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 20:47 |
| urgent query regarding vof model plz rply | Garima Chaudhary | FLUENT | 0 | July 13, 2007 02:20 |
| ATTENTION!! Validty of Fluent's VOF?? | ozgur | Main CFD Forum | 3 | February 18, 2004 18:19 |
| Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
| HELP! adding a mass source to VOF eqn. by UDF??? | ROOZBEH | FLUENT | 4 | May 29, 2003 09:54 |
