-   -   Difference between two calculations (http://www.cfd-online.com/Forums/fluent/30508-difference-between-two-calculations.html)
Lennart November 13, 2002 08:05
I will do 2 different calculations with the same mesh. Then I want to present in Fluent the difference between these two calculations. For example speed in the first case minus speed in the second case.
Hope anyone can help a new user.
Regards
Lennart
Erwin November 13, 2002 08:41
Re: Difference between two calculations
You can export the results as profiles (under /define/profile menu). These profiles can be read into a spreadsheet program like Excel where you can process and compare the data.
Lennart November 13, 2002 08:58
Thank you Erwin for your help but I want to import the result into Fluent so I can do the presentation there.
CFD MAN November 13, 2002 09:32
Hallo, read the 1st case data, You can save the 1st plot (xy) (for example man_1) and read the 2nd case-data, plot the same plot and then import man_1 and plot again.
CFD Man
Lennart November 13, 2002 09:36
Thank You CFD MAN but I want to create different isosurfaces not xy-plot.
max November 13, 2002 10:56
Use Fieldview please!
Lennart November 14, 2002 03:23
Thank you Max for trying to help me.
I suppose that Fieldview is another PC-program that you can buy?
Isn't there anyway to present the difference between two calculations in Fluent as isosurfaces?
mahdi saniee nezhad November 24, 2002 02:19
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
