Home > Forums > FLUENT
Euler model
Old   November 13, 2002, 11:03
Default Euler model
Bharath
Hello Is Euler-Euler model ..a better way to model nozzle spray ?? or do we have any restrictions in it ? If someone finds an example or tutorial other than fluent to model Spray ..please provide me with the info.
Thanks
Bharath
Old   November 13, 2002, 21:17
Default Re: Euler model
Jin-Wook LEE
As a my personal point of view, in general, DPM is better than spray model. However, mass flow rate of droplet(or particle) is very high, E-E model is preferred.
Let droplet mass flow rate, D, and gas mass flow rate, G.
In general,
D/G < 0.2, DPM without interaction between two phases.
D/G > 0.2, DPM with interaction between two phases.
The limitation of DPM is the ratio of volume flow rate, D_vol/G_vol about 0.1(10%)~0.15(15%). My personal experience, the ratio of mass flow rate, D/G exceeds 2~3, convergence has some problem.
So, E-E model is recommended for D/G >> 1.
Sincerely, Jinwook
Old   November 14, 2002, 11:21
Bharath
Hello there Thanks for the reply.However,my problem includes inlet condition of water(as a continous medium ) and air mixing .DPM model would require liquid ( water) phase to be injected as Particles isnt it ??I would like to send the inlet Liquid not as particle but as a continuous flow until the air interacts with it and by its shear force forms droplets. I did find that ..If I use DPM model ,Im able to track only finite number of particles (which is equal to the GRID size at the liquid phase inlet ). But it is required that I wanna see water slowly disintegrating to form droplets and ...not like tracing the Water particles from the very beginning !
Awaiting ur reply
Thanks
Bharath
Old   November 14, 2002, 23:46
Jin-Wook LEE
Then, it is very difficult(actually, impossible) to solve your problem by E-E model of current Fluent version.
Instead, Fluent has couple of special models for the prediction of droplet formation in DPM option of Fluent 6.0 or higher. I never tried one of these models but I felt that it's very nice.
Sincerely, Jinwook
Old   November 24, 2002, 02:18
mahdi saniee nezhad
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 7 August 23, 2011 02:52
MRF and Euler model DropsandSimulations OpenFOAM Running, Solving & CFD 0 September 4, 2009 05:20
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
