November 18, 2002, 11:49 |
Spray
Hello I have been working with the Spray model( high Speed Air mixing with Water to form fine spray ) and Would like to knw as to how..i can VISUALIZE my SPRAY ... I mean the Water Droplets..dispersed in the Gas(AIR ) Does fluent have any "DISPLAY" features to Visualize it ?.. I tried to visualize the Contours of Phases( Air and water) but really could not see the Dispersion of water into droplets...It jus showed me the Water VOF along the Downstream.
Thanks Bharath |
November 20, 2002, 00:55 |
Re: Spray
I think u can see particle tracks in "display" to see your spray if you have used DPM
November 20, 2002, 12:03 |
Re: Spray
Hello Sachin..
As I said ..The intial Fluid entering ths sytems in in continuous Flow.Supposing I try to model my system using DPM ..using surface Injection ..the DPM requires the Diameter of the particles that are injeected..so..essentially ..I lose the interest in visualizing the Droplet formation ..as the inlet itself is in droplet phase..I have been trying to use Eulerian eulerian model to work this out ..and if you have some info on the same..i would be glad to receive it Thanks Bharath |
November 24, 2002, 01:58 |
Re: Spray
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Display Modes | |
HELP! post processing for spray modelling | hamish888 | FLUENT | 1 | August 2, 2012 11:21 |
spray plume | Jay | Siemens | 0 | July 25, 2008 23:26 |
Spray slows then stops | coastal593 | OpenFOAM Running, Solving & CFD | 6 | July 31, 2007 17:14 |
spray injection | mmacrb | FLUENT | 0 | January 10, 2007 05:57 |
problems with unsteady spray simulation | Mathias | FLUENT | 1 | July 20, 2006 17:13 |
