Home > Forums > FLUENT
Need help!!: LES mean-value
Old   November 18, 2002, 06:36
Default Need help!!: LES mean-value
jayd
Dear all Fluent Users
Does any body has an experience how to display mean- value of LES transient solution data? I mean how exactly the text command should be. The Fluent document show that we have to type: 'display/calculate-les-mean'. ..and I've tried that but didn't worked. I'd like to plot 'wall fluxes' data in mean-value rather than instanteneous data.. So, please guys give me your favour.
cheers Jayd - Research in Transition - LES
Old   November 18, 2002, 10:30
Default Re: Need help!!: LES mean-value
zhhuang
you can select the report and then you will find it
Old   November 18, 2002, 10:49
jayd
Hi zhhuang, Thanks for your reply. But, could you please re-describe what and which report and what to select? As far as i understood the 'report' have no sel;ection for 'mean-value' for LES.
cheers, Jay
Old   November 18, 2002, 21:30
zhhuang
hi, jay: I mean you can select the item "report">"surface Integral" or "volume Integral" in the menu,then will pop a windows,you can select the item you needed.
regards zhhuang
Old   November 21, 2002, 10:07
jayd
Hi zhhuang
Thanks again. But that's not what i meant. I need to plot skin friction vs. REynolds number in'MEAN-VALUE' not instanteneous values. Have you any experinece running LES in Fluent?
cheers Jay
Old   November 24, 2002, 02:09
mahdi saniee nezhad
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Old   November 27, 2002, 10:45
jayd
Hi Mahdi,
What do you mean that you have the problem with this title. Are you working in Fluent-LES as well? How do you manage to get the mean results?
cheers, Jay
Thread Tools
Trackbacks are On
How to conduct transient LES simulation tianrenshui311 FLUENT 0 November 15, 2010 14:21
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 10:56
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
