November 6, 2002, 14:36 |
Using two UDFs in a single geometry
Hi *, I want to use two UDFs in a single geometry. Does anybody know if it is possible?
I have a simple channel, and I want to define one UDF on the top wall and another UDF on the bottom wall. Please reply if you have any idea about it. Thanks. |
November 6, 2002, 16:16 |
Re: Using two UDFs in a single geometry
I was trying to do a similar thing. I found that I could only put 1 udf on any one boundary condition (however it may be possible to different types of udf (e.g. velocity and a property) on a single b.c.) Therefore you can just define 2 different boundary conditions for each part..and 2 different udfs and then just set them up in the boundary conditions. Glenn
November 7, 2002, 04:13 |
Use two function in same file. Give different name to each function. It will definatly work. If you any doubt reply me with your problem in detail Regards, Rahul
November 21, 2002, 14:08 |
Thank you
You have solved a big problem that I was facing. Thank you Glenn and Rahul. I really appreciate your replies.
Display Modes | |
[ICEM] Create geometry (iges or step file) from fluent mesh | muketa | ANSYS Meshing & Geometry | 10 | August 5, 2015 06:38 |
importing geometry into starccm | krishna086 | STAR-CCM+ | 0 | November 28, 2010 22:54 |
car geometry | Arjun | FLUENT | 4 | September 1, 2007 16:08 |
urgent help! car geometry | Arjun | FLUENT | 0 | August 13, 2007 14:07 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
