Viscosity and accuracy
Old   November 19, 2002, 02:47
Default Viscosity and accuracy
moiami
I'm quite concerned with my process fluid viscosity. The viscosity that I have to input into Fluent may fluctuate in +/- 0.1Pa.s depending on most probably the temperature and how much I have processed/stirred it. It's a Newtonian fluid, by the way. Will the simulation results get affected so much or can I just ignore this viscosity change and just stick to one value? It's quite difficult to measure everytime I run the process. For your info, my velocity components I got from the experiment is in the range of 0.001 - 0.500 m/s.
Thanks
Old   November 19, 2002, 04:44
Default Re: Viscosity and accuracy
Jin-Wook LEE
For your reference, for the TURBULENT FLOW, couple of tens % or hundreds % difference of molecular viscosity hardly affect to the flow pattern because turbulent effect is predominant. (In general, 100~1000 times larger than molecular visocosity effect),
Viscosity is very important for the LAMINAR FLOW. But couple of % difference in viscosity is not severe even for the laminar flow.
So most of all, you should give the information for the absolute value of the viscosity. That is to say, 0.1 Pa-s is big or small, compared to the average value ? Because, as you may know, relative comparison is important in the engineering as well as simulation.
And you should check that your flow system is turbulent and laminar.
As my personal experience, couple of % difference in viscosity(molecular viscosity, or laminar viscosity) is not so severe problem even for the laminar flow.
Sincerely, Jinwook
Old   November 20, 2002, 00:21
Alamgir
or u can input that small defferences by the help of user defined function (UDF).
Alamgir
Old   November 20, 2002, 21:04
moiami
Thank you both. I'll check back my viscosity value.
Another question: How to input the small differences by the help of user defined function (UDF)?
Is there an example in the tutorial or anywhere on this that I might have a look at?
Old   November 21, 2002, 07:16
Philipp Beierer
yes, check the manuals, the subject about udf's. There you'll find an example about how viscosity is modified e.g. as a function of temperature
Old   November 22, 2002, 22:43
moiami
Thank you. I'll check it out.
Can a turbulent flow converge in laminar simulatio KM CFX 7 December 5, 2019 01:25
Artificial Viscosity Luiz Eduardo Bittencourt Sampaio Main CFD Forum 12 November 13, 2011 11:21
Tuning a code for accuracy Petrov Main CFD Forum 1 August 9, 2011 18:52
Vortex methods with variable viscosity? labarba Main CFD Forum 15 February 4, 2005 05:57
Numerical Viscosity? P. Diao Main CFD Forum 9 August 21, 1998 08:46
