November 19, 2002, 04:12 |
Injection of partical into flow field
Hai all, I have studied particle deposition mechanism in the flow field .I am having problem with injection of particle in the flow field. Now I am introducing group of particle streams in the compressible flow field. In the flow field I have introduced small perturbation but the particle streams are separated before the perturbation.
Can anybody give me some ideas to overcome this? I would really appreciate the help. thank you M.Mahendran |
November 19, 2002, 22:58 |
Re: Injection of partical into flow field
First thing, do u wanna introduce particle as a pulse or continuous injections. r u running multiphase flow? if so, then which one? u have to run multiphase mixture model or eularian model, then primany phase would be compressible one and the secondary should be particles. and put the boundary condition for continuous injection. outher wise u have to run trasient flow in multiphase modelling and write a UDF for the pulse. anything more? Alamgir |
November 24, 2002, 00:54 |
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Porous domain in a flow field | rikio | CFX | 7 | August 25, 2009 22:39 |
flow field residuals into posdat? | nicola | Siemens | 0 | February 9, 2007 10:54 |
axisymmetric main flow + injection | Stephan | FLUENT | 1 | January 19, 2006 11:43 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
