Home > Forums > FLUENT
Diffusion of CH4 in quiscent medium
Old   November 23, 2002, 08:30
Default Diffusion of CH4 in quiscent medium
satya
Hi fundoos!!
is it possible to model diffusion of methane in air using FLUENT without any reaction.i want to know how the concentration of methane changes with time.plz help me how to model.
thanx,satya
Old   November 24, 2002, 01:25
Default Re: Diffusion of CH4 in quiscent medium
mahdi saniee nezhad
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Old   November 25, 2002, 11:29
cfd guy
I believe you can use the Eddy Break Up (EBU) Model. Make sure that you'll not set any finite rate chemistry and set the A constant of the model to 0. Thus, you'll have no reaction in your domain. However you'll need to solve the heat transfer equation. If you're not interested in the energy fields perhaps you may use a multi-component model. I'm not a FLUENT user, but I believe that you can do it. Every commercial code has multi-component capabilities (I think).
Good luck, cfd guy
Old   November 25, 2002, 11:48
Erwin
I don't think one should use a turbulent mixing model in a quiescent fluid. Just use the multi-component diffusion model using the right binary diffusion coefficients.
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Diffusion Flux calculation in porous medium gemini Fluent UDF and Scheme Programming 14 October 7, 2010 17:23
porous medium and reactions Valeria FLUENT 1 July 10, 2009 03:58
Modeling air phase diffusion w radioactive decay John Tauxe Main CFD Forum 0 July 3, 2007 15:55
convection, diffusion, advection, dispersion Lam Main CFD Forum 7 May 18, 2007 12:04
