-   -   Reynolds stresses not converging! (http://www.cfd-online.com/Forums/fluent/30600-reynolds-stresses-not-converging.html)
Darrell Anthony Egarr December 2, 2002 05:17
I am having a problem trying to get the Reynolds stresses to converge in a problem which is modelling the flow of an incompressible fluid.
All they are doing is oscillating.
Does anyone have any suggestions?
DAE
alireza December 3, 2002 17:22
Re: Reynolds stresses not converging!
my friend u will have a lot problem with this model. u can have very good results by others models in compressible flow. if u have to work with this model at first u must use other models and at last use this model.
cfd guy December 5, 2002 07:54
I don't know what is your case but, here I go. First try to use a first order differencing scheme (UPWIND) for all variables with false timestepping (if you're running on steady state). Relaxation factors are also something to take care. Are you using a commercial or your own code?
Good luck, cfd guy
