-   FLUENT (
-   -   UDF - C_NFACES (
St.Schmidt December 10, 2002 19:49
Dear All,
In a routine DEFINE_SOURCE(name,c,t,dS,eqn) I want to get the number of cell faces by setting
int n = C_NFACES(c,t); /* it should be integer */
to run a
c_face_loop(c, t, n) {...}
My problem is that I get an error message from the compiler. I am not v/good at C as you can imagine by my question. I have tried to put C_NFACES(c,t) directly into the loop header c_face_loop(c, t, C_NFACES(c,t)) - but with no success.
Any help appreciated.
Markus December 11, 2002 04:11
Hi Stefan,
Most likely your problem is that several macros simply do not work in interpreted mode, among them is C_NFACES. The workaround is to use the compiled mode which definitely works.
best regards,
