December 17, 2002, 11:13 |
combustion models
Hello again!
I am trying to model combustion within a cylindre. The problem is that ignition occurs near the walls due to the k/e ratio. Wall functions don't help. My next approach is to write a UDF, but I would have to implement the whole EBU-combustion-model again (from my point of view). Is there anybody who has experienced the same problems and has worked out possible solutions? Please contact me! Thank you! Regards, Peter |
December 17, 2002, 12:32 |
Re: combustion models
Appendix:
At www.rz.unibw-muenchen.de/~j9lp0407/ one can see 2 tiffs of my problem. Ignition shall only take place in the area on the lower left. There I patched with a higher temperature and higher product mass fractions. The problem is that the eddy dissipation model does not work correct in the laminar sub-layer near the wall. Instead, there is a high reaction rate. Regards, Peter |
December 19, 2002, 09:31 |
Peter,
Are you using the finite-rate/eddy-dissipation model or standard eddy-dissipation model ? Also, could you give more information about the problem you are trying to model ? Dave |
December 19, 2002, 09:50 |
OK. I am modelling premixed combustion (2d) of n-octane/air in a cylindre. Ignition shall take place in the lower left corner. I initialised with T=786K, p=922400 Pa. The material settings are piecewise polynomial for the cps, except n-octane (no data in the database), sutherland-theory for viscosity. The I marked the ignition area and patched with T=2600K and mass fractions representing fully burned mixture. Due to the k/e-Viscosity-model ignition takes place near the wall after about 10exp-4 seconds. I have also used a boundary-layer like grid and the k-w-model for viscosity, but achieved the same results. My idea now is to write a UDF that avarages the turbulent timescale. I think I would have to re-program the whole combustion model for that purpose, so I asked whether someone has already written a UDF modifying the combustion model. Other hints for solving this weired problem are also welcomed. I hope, this describes my problem. If you need more detailed information, please write again.
Regards, Peter |
Different combustion models in two domains-how? | tony | CFX | 3 | October 2, 2007 13:13 |
Are combustion models actually any use? | None given | Main CFD Forum | 22 | September 24, 2005 11:37 |
Enable combustion models | Swarup | FLUENT | 2 | September 23, 2005 07:29 |
Combustion models and code | Bak_Flow | Main CFD Forum | 0 | March 5, 2005 10:42 |
COMBUSTION MODELS | stefano | Siemens | 1 | May 15, 2003 07:09 |
