Von Karman Vortex
Old   December 13, 2002, 17:13
Default Von Karman Vortex
Rodrigo Madariaga
Hello, before I make a model wing to test in my wind tunnel and compare it with CFD results, I want to check out my Turbulence model. I will do this with a simple cilinder. My question is if I should try a time dependant solution because of the von Karman vortex. Are they really important in the surface pressure results? The wind tunnel speed is 30 m/s and the cilinder diameter is 100mm
Old   December 19, 2002, 15:07
Default Re: Von Karman Vortex
Marc
Hey! The karman vortex is a laminar effect, taking place at about Re = 100. At Re = 2E5 all the transient effects will be modelled in your tubulence model (quasi-static).
von Karman vortex street. Vortices formation mechanism. mnvl Main CFD Forum 1 February 24, 2010 17:53
Are these reverse von karman vortex street? quarkz Main CFD Forum 1 August 20, 2009 15:15
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 14:44
Von karman Vortex street yoshi Main CFD Forum 6 September 10, 2005 22:09
Von Karman Vortex Rodrigo Madariaga Main CFD Forum 0 December 13, 2002 17:12
