Symmetry
Old   December 18, 2002, 11:15
Default Symmetry
Chris
I tried to build a simple square pipe with Gambit, and then in FLUENT, put in boundary conditions at the inlet (fixed total pressure) and at the outlet (fixed static pressure).
I had expected the filled-in plots of my results to be symmetrical on all four faces of my pipe, but they are not! There were no energy equations used, nor gravity, so I don't understand why I get different values for each of the four faces.
Does anyone know what I could have possibly done wrong? Does the axis along which I defined my square pipe have anything to do with it (e.g. -x-y-z or +x-y+z etc)?
Tks
Old   December 18, 2002, 17:24
Default Re: Symmetry
Amid Naz
did u define the 4 walls BC indentically? I guess no reason to have different results unless u made some mistake here or there..I suggest to repeat the problem from scrach, it is easy and can be redone fastly, GOOD LUCKK
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
Forces in Symmetry Matt CFX 2 February 25, 2009 05:41
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 07:09
radiation and symmetry Mark FLUENT 2 November 4, 2004 13:50
