December 30, 2002, 01:38 |
error
Sir,
After some iteration the Fluent window gave following error.. EOF on stderr. The fluent process could not be started. Error: Cortex received a fatal signal (SEGMENTATION VIOLATION). Error Object: () and after that either I have to kill the process or restart it. I dont know what is wrong help me please. Thanks |
January 3, 2003, 04:19 |
Re: error
Sometimes it could be happened for improper geometry. and also if the case and data does not mach each other.
bye Alamgir |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
