December 18, 2002, 06:52 |
Steady state at vof!!
I wanted to know if we can get steady state, in vof or not, I mean in the steady state condition, should the flux net of the field equal to zero or not? NOTE :The initial condition and all the boundaries of the unsteady state are known.
December 18, 2002, 08:39 |
Re: Steady state at vof!!
Yes, you can get steady state at VOF. You should use the implicit scheme in VOF model. You will get the flux net.
December 21, 2002, 05:40 |
I have used this implicit scheme, but the final net flow rate is not equal to zero.
December 21, 2002, 20:48 |
How did you calculate the net flow? Net flow of which fluid?
Nancy |
December 22, 2002, 04:23 |
net flow rate calculation is done by program.
December 22, 2002, 04:54 |
Yes for steady state, the net flux is zero, if not, your solution is not converged assuming that your program is correct.
For unsteady state, [Total accumulation+initial mass=total input of mass-total output of mass] for that time. If not, your program is wrong/ solution didn't converge. Hope this helps. Nancy |
December 22, 2002, 07:27 |
What do you mean by accumulation.. this sumation is calculated on what... thanks
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
plz help,urgent, vof model steady state | Garima Chaudhary | FLUENT | 4 | March 15, 2018 12:22 |
Solver for transonic flow? | Martin Hegedus | OpenFOAM Running, Solving & CFD | 22 | December 16, 2015 04:59 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
VOF steady state : river : floating point error | marion | FLUENT | 1 | May 31, 2007 09:44 |
