December 22, 2002, 16:18 |
Turbulent Parameters !
Hello
During the Modelling of Turbulent Multiphase Flows, Fluent Asks for Turbulent Parameters such as Turbulent Intensity and Length ?? Which Lenght is it talking about ? Suppose , if You model a flow in a duct and a large domain outside at the exit of the duct(pressure outlet ) to see the flow spreakd out ...wht would be the characterisitc length at the inlet and outlet? Thanks Bharath |
December 29, 2002, 08:53 |
Re: Turbulent Parameters !
Turbulence intensity at the inlet of the domain depend on degree on turbulence at that location suppose if u r inlet is atmospheric that around 10% of Turbulenc intensity is enough. About characteristic length its given in the mannual that it should be around 70% of inlet dimension.
For further details u can refer to Fluent mannual chapter 9. Hope its work for u Regards Sohail |
December 29, 2002, 23:11 |
hi sohail
Thanks for the reply.well..how about the Characteristic lengths for an outlet that is bigger than the inlet dimensions ? such as an expanded outlet ? thanks Bharath |
Aeroacoustics, turbulent parameters and convectiveOutlet | Bertrand | OpenFOAM | 0 | December 21, 2010 16:53 |
Turbulent Dispersion for Coal Combustion | gravis | CFX | 2 | March 23, 2010 23:56 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
Comparison between turbulent parameters with analytical or experimental results | fareedmangi | FLUENT | 0 | June 2, 2009 10:41 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
