-   -   HELP! divergence detected in AMG solver (http://www.cfd-online.com/Forums/fluent/30740-help-divergence-detected-amg-solver.html)
ann January 1, 2003 22:20
I'm calculating a stage of axial compressor, but when I began iterating, it will appear such error:
Error: divergence detected in AMG solver: pressure correction
Error Object: ().
I have tried to reduce the under-relaxation factors of pressure and it's useful in some cases. Later, I increase the grid number and I also adopt the above measures, after about 2000 iteration the above error appeared again.
Could anyone tell me how I should do and what I should do?
Thanks for any help!
regards ann
zhhuang January 2, 2003 21:10
Re: HELP! divergence detected in AMG solver
ann check your B.C first!And the initial condition is also important .
ann January 3, 2003 05:01
zhhuang,thanks for your response!
My calculating case is obtained from NACA report. The inlet B.C. is inlet total pressure(about 67,000),inlet total temperature (300k) ,inlet initial gauge pressure ( 65000) and hydraulic diameter 0.0502meter(the pitch). The outlet B.C. is 74000.
Any problems do you think?
Thanks in advance!
Regards, ann
zhhuang January 4, 2003 02:27
ann, I think you can use the 1st order method firstly then use the 2nd order ,this maybe can help you! zhhuang
