January 3, 2003, 17:29 |
Urgent
Hi CFD ppl, I have set a CFD model setup with a mesh 1. I forgot to save fluent journal file for this problem. How can I just copy all the setup for another mesh size (mesh 2)?
Please note that in mesh 1 and mesh 2, I have exacyly the same domain/zone name. Only the mesh is difference. Thanks in advance. Brandy |
January 4, 2003, 07:02 |
Re: Urgent
Hi, Most settings are copied over to a new case by using the text command /file/write-bc/ (which suitably enough writes settings to a formatted text file - you supply the file name) and /file/read-bc (that reads it in again). This should work if you have identical zone-names, but I am not sure if all models (e.g. multiphase settings and so on) are transfered. Check before starting to solve.
Regards Anders |
January 8, 2003, 01:58 |
Re: Urgent
Thanks Anders, But I am getting an error: -- Error: interpolate_profile_field: thread 7: profile "" does not exist. Error Object: #f ---- Any idea whats that one is?? Where can I get the error list and the way to get rid of it?
Any help from any one would be appreciated. Brandy |
Urgent - Polyflow - particle tracking visualization -Urgent | shafaatht | ANSYS | 0 | October 13, 2010 04:56 |
Urgent, Urgent, a UDF problem, PLEASE HELP!!! | Max | FLUENT | 1 | September 24, 2010 20:30 |
Urgent...urgent...plss!!! | astronome | FLUENT | 0 | October 16, 2009 07:17 |
tmerge urgent urgent | jessica | FLUENT | 4 | July 15, 2006 13:37 |
very urgent pleasade:Cl and Cd values for airfoil | Liaquat | FLUENT | 2 | April 27, 2006 12:20 |
