Home > Forums > FLUENT
mpg production
Old   January 13, 2003, 09:54
Default mpg production
Rat
Hi again, Does any body know a good way to produce mpg's in fluent to visualize time dependent problems. (Windows so cannot dump graphics window in a macro every time step or so). Tried using key frames but they write over the previous one. Thanks, Rat
Old   January 18, 2003, 16:48
Default Re: mpg production
Erwin
Write a jpeg hardcopy every timestep, then use a program like ImageN (freeware) to join them into an avi. This can then, if needed, be converted into an mpeg. This gives a much better image quality than the mpeg option offered by Fluent since you can use a high resolution.
Thread Tools
Trackbacks are On
buoyancy production term in turbulence model braennstroem OpenFOAM Running, Solving & CFD 5 January 13, 2012 06:43
production header flow profiles jehuty Main CFD Forum 0 June 2, 2010 08:46
Turbulence Production Based on the Curl of the Velocity Field ngj OpenFOAM Running, Solving & CFD 0 April 4, 2008 05:22
Buoyancy production for species concentration George Gerber FLUENT 1 May 25, 2006 16:56
hot to compute the production of k by RSM? Lcw FLUENT 1 September 16, 2004 07:41
