January 15, 2003, 13:56 |
Grid error
When there is a grid error owing to negative volume, how should I go about correcting that error? Thanks |
January 15, 2003, 21:11 |
Re: Grid error
I think it is for the sharp angle in your volume if you mesh stucted gid .but you can void it by meshing unstructed gird .If you mesh unstructed grid and meet the same error again ,then you can change the mesh size smaller .just do it !
January 16, 2003, 05:23 |
Re: Grid error
Thanks, I will attempt to do that!
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
