January 22, 2003, 01:49 |
How to use K-e model ...
Hi Friends I have one question in my mind. can anybody tell me more about it.
My problem is like this: tank of size 1m X 1m X 1m. the inlet is only 6mm jet flow(fluid is water) with Re=13,000, outlet is 0.003m X 1m. Now my doubt is regarding the use of K-E turbulence model for simulating the entire tank. Major part of the tank is having cell Reynolds Number less than 200. hence if i use K-E realisable model for simulating the flow in the tank, will it be correct? Is there any method for such problem( both laminar and turbulent flow in a same domain without any demarcation)? |
January 22, 2003, 03:06 |
Re: How to use K-e model ...
k-e RNG is so great for those fields which you have laminar flow and turbulent , bt any way i think you can use all k-e methods.
January 22, 2003, 03:07 |
Hi, you can select a region with Adapt/Region and Separate the selected cells (Seperate/Cells) from the entire geometry. Then, with this new volume, called " fluid: xxx", you can put on it a "Laminar Zone" in boundary condition. And select you k-e model from the viscous menu !
January 22, 2003, 03:32 |
hi, Thanks for your useful reply. For using adoption/region, we have to solve the complete domain assuming that it is turbulent flow. After this output will become basis for next adoption/ region. Therefore my doubt is regarding how to start simulating. Even in some part of the domain,if Re is less than 200 what happens if i use K-E model?
What criteria shall i use for marking laminar and turbulent regions? (i,e., Re= ?) Can you through some light on these doubts? |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
