January 21, 2003, 14:13 |
turbulent flow
Solution is not converging, tried reducing the relaxatin factors. Minimum used 0.3. can i reduce them further. or am i making some other mistake taht solution is not converging.
January 22, 2003, 03:15 |
Re: turbulent flow
for pressure use min .15 and max .35 for momentum use min .65and max .85
spectrum: LES of a turbulent channel flow finally goes to turbulent | liu | OpenFOAM Running, Solving & CFD | 6 | November 1, 2011 01:00 |
Difference between recirculation zone and turbulent flow region | ashtonJ | Main CFD Forum | 0 | September 16, 2011 03:46 |
Patch a bubble inside turbulent flow | Helmi | FLUENT | 0 | February 4, 2011 04:54 |
Turbulent flow through hexagonal circular pipe | yogesh@cfd | Main CFD Forum | 0 | November 9, 2010 23:10 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
