Home > Forums > FLUENT
Face handedness
Old   January 22, 2003, 10:12
Default Face handedness
Chris
Hi, does anyone know how to correct a "face-handedness" grid error? This jumps out at me when I do a grid check on my latest grid (took me hours to make it, darn!), and I cannot imagine having remesh the whole thing again! :P
Old   January 22, 2003, 10:48
Default Re: Face handedness
Volker Pawlik
Hi Chris,
try /grid/modify-zones/repair-face-handedness,
s.t. it helps.
If your case is 2D and axissymmetric, the error can occur due to cells lying below the x-axis.
If possible, translating in the right direction helps.
Old   January 24, 2003, 09:06
Chris
I tried your advice, and though it corrected the face-handedness, it generated a non-positive volume
I'm doing a 3-D model, by the way.
Maybe I'll try to remesh the thing, and see how things go...but if you have any more advice, please help!
Thanks Volker.
Old   January 24, 2003, 10:14
Volker Pawlik
Non-positive volumes after the handedness-repair process often indicate very bad cells. What is your highest skewness?
Sometimes the face-handedness problems occurs when you work with hybrid meshes in cases were the pyramids grow into the wrong direction or at sharp geometry angles with a too low grid resolution.
Try to check where the bad cells with the negative volume are located and remesh this part if possible.
Let me hear what the reason was.
Thread Tools
Trackbacks are On
Import netgen mesh to OpenFOAM hsieh Open Source Meshers: Gmsh, Netgen, CGNS, ... 32 September 13, 2011 05:50
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
