using injection file and parallel process
Old   January 23, 2003, 12:40
Default using injection file and parallel process
Cindy Jones
Hi, everyone
Thanks for those answers for my previous question. Now I try to use Fluent's DPM model to simulate gas-solid flow in pipe. For some reason, I have to write my own injection file. My question is when I use injection file and parallel processing at the same, Fluent always tells me "Unable to open the injection file". But if I just use single process, the injection file works fine.
Can anybody tell me it is my injection file's problem or we just can't use parallel processing and injection file at the same time? (Without parallel processing, the calculation is too slow)
Many thanks
Cindy
drag force output file on parallel computing Jackie FLUENT 2 January 9, 2012 22:55
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 02:26
Help: Batch file for Parallel Processing ( 2CPU ) SC FLUENT 1 July 15, 2003 21:34
