-   -   Error message when setting BC (http://www.cfd-online.com/Forums/fluent/30856-error-message-when-setting-bc.html)
Mnu & Luc January 27, 2003 10:24
Hello, me and my famous workmate have an interesting error message when opening a continuum BC (solid zone):
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: #f
Ray January 28, 2003 15:07
Re: Error message when setting BC
I would like to know as well. I get the same error message but only when I activate the energy equation and try to open the solid zone BC.
Erwin January 28, 2003 15:33
It means that a field in your window has not been set (it has the value #f = empty). I saw it, e.g. in a porous zone where the solid material was not set after I read a case file from one old version of Fluent into a new one. In stead of Aluminum or so the field is empty.
So, check all your fields very carefully to see if they make sense.
Ray January 28, 2003 16:18
I'm trying to specify a fixed temperature in a solid and it won't let me. I don't know what fields I should be looking at to determine why the message is occuring.
