Home > Forums > FLUENT
Different answers
Old   February 10, 2003, 04:47
Default Different answers
heydari
Hi, As I wanted to solve a jet flow, by different value initializing I get different answers, do you know why?
Old   February 12, 2003, 02:10
Default Re: Different answers
Keil
This is my guess, the calculation is not convergence yet. If you judge only the residuals, the residuals are not good to judge whether a calculation is convergence or not. So you should monitor some values at some points and when the values become constant value during iterations,then we can say the calculation is convergence.
Regards,
Keil
Old   February 15, 2003, 02:31
heydari
Thanks for your reply KEIL, you mentioned the monitoring, What kind of value (x-vel, y-vel, z-vel, pressure, k, e, ...) do you mean? In an unsteady solution, how can this be used?
Old   February 20, 2003, 08:10
Keil
I mean, the monitoring is a certain physical value at an arbitrary location in your calculation domain.
How about the following procedure?.
First, you define the location and physical value(for example, velocity magnitude or something). Second ,Define the property(monitoring at every iterations or time steps) on the panel Solve-Monitors-Surfaces. And then calculate it.
I recommend every iterations monitoring because we are able to check whether the calculation is convergence or not in the time.
Regards,
Keil
Old   February 25, 2003, 05:04
heydari
thanks for your help,
Thread Tools
Trackbacks are On
Steady State Vs Transient answers Kushagra CFX 15 August 16, 2016 19:51
inconsistent answers Robreid FLUENT 0 May 27, 2011 16:15
[TGrid] Simple Question (Simple Answers?): Edge Length adjustment for tet mesh booz ANSYS Meshing & Geometry 0 August 29, 2010 12:39
Coodles anja OpenFOAM Pre-Processing 33 January 14, 2010 10:05
The answers of the case tutorialsstressFemFoamplateHole seems wrong dandes OpenFOAM Pre-Processing 3 March 24, 2006 04:31
