halving model
Old   February 10, 2003, 04:52
Default halving model
John
If you split your model in half, to reduce computations, do you also have to reduce the variables, such as velocity or pressure by half? Thanks,
John.
Old   February 10, 2003, 06:06
Default Re: halving model
david
I think it is imposible! If you do that,you will lost much important data what you set first,the numeration is inauthenticity.
Old   February 10, 2003, 09:37
Marc
I guess you mean, that you want to use a symmetry condition (half of the modell bordered by a symmetry plane ). You should use symmetry wherever possible, but check your case carefully, if it is! For example a geometrically symmetric flow case can possibly be non-symmetric concerning the BC's. Or imagine a Karman vortex street flow. Without knowing the solution you would expect to be able to model the half of the case.
Don't change your variables by halfing them! 60 mph stay 60 mph, even if you cut your car through the middle plane. In contrast to that you have to change mass flow values, of course (you change the cross-sectional area, right?).
Greetings Marc
Old   February 10, 2003, 10:19
John
Marc,
Yes I do wish to use symmetry, this is exactly what I was looking for. Thanks
John.
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
